Compound turbo question
- Replies 16
- Views 3.7k
Mopar1973Man 6 posts
Tymatthew 5 posts
AH64ID 3 posts
Dieselfuture 1 post
A stock turbo would work really well with a Super B Special for towing twins. You'd probably have to do some wastegate porting as well, but it would be fun in town and great with a traile
Yes the exhaust would go to the HX (or HY) and then to the Super B Special. Using the stock turbo in twins usually has the WG open around stock levels, or lower, so that the exhaust press
That's why I'm staying at level 3 on the quad. Whither my turbo and 7x10 I can get to where I need and stay just below going in danger zone. If i use wiretap, it will be more powerful but will get in
Would my super b special and a hx40w be a good set up for a compound system?
