- Replies 36
- Views 11k
Silverdodge 10 posts
Voltronics 9 posts
Me78569 8 posts
Mopar1973Man 4 posts
The only dumb question is the one you dont ask. We all learn by asking those questions. Never let yhat bother you. I am still learning.
We dont even know what size turbo he has. We do know he has a smarty and ddp injectors. Too much fuel will choke a turbo. Typically 150's are a perfect fit for a 60-62
Personally I prefer using a smaller turbo with a wastegate on a DD or towing duty truck. The waste gate can open and bleed off excess gas at the top of the rpm range without lossing low end spoolin
The turbo I have is a 60mm schwitzer turbo 150 ddp injectors and a hot rod vp44 I bought the truck with all of this and all have less then 6k miles I’ve driven the truck for about 1k miles and notice the turbo doesn’t spool past 8psi until about 2k rpm is this slow? Also the most the turbo has spooled too is about 25psi because it runs out of rpm and smokes really bad down low in third fourth and fifth gear
