Cummins big cam 365 and Cummins C brake.
- Replies 10
- Views 3.8k
Evan 5 posts
NIsaacs 2 posts
dave110 1 post
Dieselfuture 1 post
04mach1. He left. I'd post it down in the other vehicles section.
It is possible you have the wrong lash adjuster, they are sized by your turbo and how much retarding turbo boost you make. Here is a link to the lash adjuster kits depending on your CPL and turbo type
Been running mine on well water since it was new.
Maybe this is the best place to post this?Theres a cummins big engine guru here that i cant remember his name.
I'm trying to get more breaking from the big cummins. I'm dropping solenoids or butterflies at 1800-1500 rpm. I've rewired so all solenoids come on all the time the 3 way switch is gone but still losing engine braking at high rpm.
365 has no trouble idling with switch on sounds like only one solenoid is on.
At and idle I flip the switch motor just about dies then powers through and idle at about 700rpm chugging right through the brake.
I'm not entirely sure how the system even works.
Thank for any help.
