- Replies 8
- Views 1.3k
Air leaks. Typically occur on the suction side where there is no pressure but vacuum that draws air in. What happens is you park the truck it continues to draw air into till the system has lost prime.
This caught my eye. I assume you meant o-rings. Or what am I missing?
Good catch my friend. O ring would be correct. Though I am working on an auto eject tube.
Truck is on its third lift pump. Have to pull start, to get started. What am I overlooking?
