No bus, no cluster, truck does run though
- Replies 27
- Views 12.8k
Beam52 13 posts
Mopar1973Man 7 posts
dripley 5 posts
Alexio Auditore 1 post
I will take stab at it. I think the 900 codes are all instrument cluster codes but not sure. If so your cluster maybe bad or you justmight need to pull it and clean up the contacts on the two connecto
How did they pull up high voltage to the ect and map over boost with no dtc detected? Both of those are dtc's and should display a code #. I have been dealing with a high volt code on min
Others will be along. Kind of slow on the weekends sometimes. It is probably not your sensor but that o e is cheap enough to try. I have a couple spares. And unless you have some mods that would requi
Hey everyone! I have a 2002 Dodge CTD auto with 277k. I’m getting the “no bus” message on my odometer screen with codes 900 920 921 940 950 and 999 on the self check. The CEL, ABS, low fuel and air bag lights are on. I’ve cleaned up the connections at the PCM and fuse block, cleaned grounds and still no fix. The truck does start and drive normal so I don’t believe it’s the PCM. Any input is welcome thanks!
Edited by Beam52
