another problem with the truck
- Replies 7
- Views 2.1k
Popular Days
Check the automatic shutdown relay; it may be going bad. You can also give the wire harness the old tug and shake test with the engine running.
I drove maybe 300 miles yesterday very steady and it is fuel related, any time I had to pedal it a little for a hill it was bucking really bad, I did swap the ASR for the wiper relay before I set off
Did 400 mile today into South West Wales to drop of my house build reciepts for a tax accountant to process my tax reclaim... we get 20% Vat back on new build house materials costs, my truck must have smelt the £££ as on the way back in lockup OD accelerating a little uphill engine seemed to just stop for less than a second but then back to normal with a clunk as the trans was driven again.... that is the best I can describe it,
just like a manual trans and coming off the throttle and then straight back on it , I hadn't got the Modis with me so couldn't check anything, but no codes on dash, I don't think the trans is dropping out of drive as engine revs do not rise in fact all engine noise stops, I don't think it's fuel as there is no indication of it happening, no misfiring or rough running just off then back on, without the VP does odd things if FP is low as I did see 7 ish psi a few times today but I don't think it was the same time as this problem happening, this happened 4 or 5 times on the way home ??
I have to use it tomorrow but I'm going to take the modis and monitor the apps first and then check the whole lot while driving.... sounds electrical to me
