Looking for Staff Members
Hello. I'm searching second best option for headlights. I know retrofit with morimoto projectors ate the best but $$ is the issue at the time. Any decent aftermarket housings available? Looking for good low beam, high beam isn't so important! Already have enough auxillary lights so I can see far! Also has to be with two bulb housing because my trucks headlights have been modified to meet European standards ( Hella projectors in high and low beam ). Light output is is junk!! Low beam has now H7 bulb and high beam is HB3 bulb! Sorry long story but dark times are coming :) and greetings from Finland!
  • Replies 44
  • Views 7.5k
  • Scott, the man installing my gas line, gave me this today. Came off a 40 model Plymouth. Old model Rams head.  Darn thing even fits on the hood.
  • The truest statement.  When I'm fully lit I have 7 different driving lights facing forward...2 crappy headlights, 2 crappy fog lights, and 3 6.5" hi-lights on the bull bar...and I'm lifted 12 inches.
  • OPFTL.....Old People Follow Tail Lights is my motto.    When I do venture out after sunset I use my 9104 light blubs with stock head lamp assemblies and wiring.  The low beams (80 watts) wit
Ok this appears to be more like what your running.
https://www.theretrofitsource.com/projector-kits/retrofit-kits-vehicle-specific/2002-2005-dodge-ram-headlight-package.html
The first kit doesnt have projectors I dont think.  And I think is plug and play.
The second kit appears to be every thing and also over twice price.
Edited by Evan
the retrofit source is the place to go,  that or light werks
use the article I created it gives you what you need for the mini h1's just run the d2s's if you want more light.  the relay system is the same though.
