New to this forum, seems like a knowledgeable group of guys (shout out to y'all)
However I'm having issues with my 2001 5 speed. She has a quadzilla adrenaline tuner, scheid diesel 100hp injectors, and an edge boost elbow. After installing the injectors she has a slight white haze coming from both the exhaust and the engine compartment. Both are very light. The exhaust gets denser when accelerating, and sometimes turns black. It seems to smell normal (not sweet like coolant, or like burnt oil). What could cause these symptoms if of concern at all? It also is is jerky/studdery at around 1200 rpm, but smoothes out at higher rpm, or harder throttle input.
Also I have a stock clutch, with very low mileage on it. It seems to rattle under harder acceleration, is that just due to the clutch not liking the torque?
Warranty work is #1 choice. If you want to send them in we can help. Scheid under rates their injectors their 100HP is closer to most other brands 150HP.
