47RE Transmission Temperature Port?
- Replies 14
- Views 11k
Case in point, When the torque convertor lock up failed in my transmission I noticed the temperature elevated from a cruising normal of 160°-170°F to 190°F and when going up long 6% grades, 5-8 miles
This is the line, on the side of the engine, before it enters the first cooler.
OK...I'll take a pic and post when I wake up tomorrow am. It is similar to what @IBMobile just posted...the difference is that mine is closer to the transmission right after the line exists the trann
Hi folks, I am looking to tap into the tranny oil on my 98.5 47RE transmission. I am unsure where to thread in the gauge temperature probe. I would rather not be reading oil temps after it has been though the cooler and is re-entering the tranny. I was thinking it would be better to read the hot oil as it exits the tranny. No?
I was under the truck today looking around for a test port plug. On the RH side I see these two plugs as shown in the photo. Am I even on the right track here? If so, which one is preferred? Thanks, Keith.
Edited by keithb7
