- Replies 13
- Views 3k
dripley 7 posts
Dieselfuture 3 posts
Haggar 2 posts
dave110 1 post
Did you have the snap on with you? I would seriously look for those funny voltages you get with the map sensor etc... I agree the 216 is disheartening.... and could something going on i
Got you covered.......
I am home. What a week. The only bad thing after the pump install is my MAP sensor failed. I think it failed when the pump went whacky on Sunday, but did not have a code. Any way drove it home under r
Had some weird things going on coming back from Atlanta last night. Stuck in slooow traffic thru down town the engine jumped in idle to a bit over 1000 rpm. It also started surging about 250 more rpm up down in an even pattern for about 10 seconds. Did it it again 3 or 4 times getting thru town. The temp gauge dropped out also. Matter of fact it would only do it while the temp was out. Not sure how they are related. This happened a few more times on the rest of the trip except very little surging but had the elevated idle. It also only did this at very low speed or idle.
Sitting at my sons work waiting on him so I can have a warm dry place to check it out. So I pulled out the old SG II, plug it up. Had a 234 which I believe was an old code I had not cleared out from a good while back. But then I read the other one, 216. Damn. After 270k maybe she is giving up the ghost. Its just the temp dropping out when does it does seems weird to me.
I cleared both codes and they have not come back. It actually did it for a brief couple seconds while sitting here. That's when I broke out the SG.
