Headlights - 2nd Best
- Replies 28
- Views 6.4k
Me78569 7 posts
dripley 6 posts
Evan 6 posts
Mopar1973Man 3 posts
OEM sport lights. The others are ok and are best suited for retrofitting. however by the time you are done finding oem sport lights plus a relay mod you could have bought c
Already done the sport headlights with relay mod and still very poor for lighting. Sport headlight do not product more light. The Aux inboard lights is an narrow vertical band of light which is not us
Same here the LED retrofits are very blinding. I've got most of my trips on narrow 2 lane roads without much of a shoulder. At least the HID's have a good cut off line of the low beam wit
I am looking for the best sport headlight available. I can't afford the RetroFitShop Mini or D2S setup at this time. What are the best sport replacement unit available? TYC, PERDE, Something else from Headlightdepot.com? I will most likely be doing the relay/harness setup found somewhere here to update the wiring. I am looking for the best fit after the best pattern available that is non Morimoto retrofit.
What is your experience so far with the best replacements? I currently have the standard 2 bulb setup that doesn't produce much light due to age of the original housings.
