1998.5 SLT Laramie power seats HELP!
- Replies 14
- Views 2.7k
Waydin_Stewart 6 posts
IBMobile 4 posts
dripley 1 post
kzimmer 1 post
Have you tried hot wiring a motor to see if it does anything
I think this is the wire diagram that will work for you. To test a motor apply 12 volts to one wire going to a motor and a ground to the other wire. To test the driver power seat horizontal moto
I have a 1998.5 4x4. I recently purchased a 1998.5 2x4 parts truck. It has power leather seats in it and the same exact plug under the drivers seat as mine. I installed the seats in my truck and installed the power seats breaker from the parts truck. And nothing. No click, no noise, no power to them. Is there another plug under the dash or another fuse I haven’t found that needs to be put/plugged in to make them work.
