Squeal/siren noise! Please help!!!
- Replies 50
- Views 10.5k
ColoradoColt 23 posts
dripley 7 posts
JAG1 5 posts
Mopar1973Man 4 posts
I would change the rear end fluid and see whats in that fluid. Dont just pump it out pull the cover and have a good look in there.
The last time I was experiencing a harmonic sound like that, it was in my work truck (Freightliner) you could only hear it in the cab, and it was rpm related. and the noise just started during a trip,
Well if you are hearing the noise while coasting, you have no boost pressure to make a noise.
My truck for the last few weeks has been making an awful squeaking or siren sound from what seems like the transmission. Does not do it while I’m stopped or stopped in gear revving, it also seems like it gets quieter when I smash on the brakes? Any help would be appreciated!!!
Also it seems to do it more once truck it up to good operating temp.
Edited by ColoradoColt
