47re for 2001 4wd
I'm looking to buy a core 47re for a 01 4wd. Will be built with a triple clutch converter, billet input and intermediate shafts and aftermarket valve body. What year transmissions will work for this? @Dynamic can you provide any info? I'll most likely be buying a valve body from you and using whatever converter you recommend. This is a long term build with parts bought as i can afford them.
  • Replies 24
  • Views 4.2k
  • Late '99-'02 47's are interchangeable. As long as it has the plastic transducer. You can convert the early metal style transducers over to the later plastic one fairly easily if need be. Just avoid th
  • Thats right, I just paid 30% in import duty and Vat for the quad and assassin, but it's compound so it would be.. lets say 5k for a trans, 1500 for core, and 600 shipping, $7100 import duty is th
  • If you're paying more than about $150 for a 47RE (with converter), you're paying WAY too much. A 48RE is a whole different story, though.
You might want a 48re instead.  48re is 2003.5-2007.5.  They are very similar transmissions and are pretty much interchangeable...except for maybe the electronic kick downs.  But there are certain upgrades in a 48re that make it a stronger platform...like 2 more OD clutches, more clutch teeth, 2 more planetary sun gears, 2 more seals and planetary made of steel instead of aluminum in the 47re...and a few other minor upgrades.  I would imagine that upgrade parts would be similarly priced.  The 48re might even be easier to find.  Just a thought...
Edited by Bullet
Late '99-'02 47's are interchangeable. As long as it has the plastic transducer. You can convert the early metal style transducers over to the later plastic one fairly easily if need be. Just avoid the older 12 valves as their cases are likely to be missing a mounting boss you'll need for the shift linkage.
A 48RE will have the wrong style neutral safety switch, and no real easy way to adapt the one you need. 48RE cores are quite expensive as well. 47RE cores are dime-a-dozen.
sorry for the hijack.  but if 47re cores are a dime a dozen please get me one and ship it to the UK :whistle: then I can start ordering parts for the build
Can't help you there... LOL
@Dynamic what kickdown lever do you recommend with your valve body? Which triple disk converter? Daily driver 4-500 hp with occasional towing of 15000 pounds.
If you're referring to the intermediate band lever, then I would recommend the TCS 4.2 lever at that power level. You'll also want a billet input shaft at that power level.
Stall speed will depend upon your specific setup, but either DPC or Goerend for the converter would be my recommendation.
Intermediate band lever yes. Going with billet input and intermediate shafts. I'll start buying parts when i can afford them.
If you find that pile of dime a dozen 47re cores...let me know where it's at cuz I will pick one up too.
Around here i guess a dime is equal to about $400. But I'll have a core valve body and converter to use when I need them and i have time to shop around.
Damn...the exchange rate where you are is horrendous!  Around here a dime is worth about 10 cents...practically worthless.  I'm bringing my piggybank up to where you live and cashing in!  Then I'm gonna retire... :spend:
...and they said I didn't have a retirement plan...pffft.
People around here think anything Cummins is gold. Thats why I'm starting to shop around now so i have time to find a deal. I refuse to overpay for a core that I'm going to replace half the internals of.
Cummins = gold...gold = $1500/ounce...16,000 ounces = Cummins.  I'm gonna be rich!
Some Cummins stuff is more valuable than others. A 47RE is not among the "more valuable".
I've never found a 47 for 150. Think 400 is the lowest ive seen .
I haven't looked in dynamics area bought 10hours from me.
I understand this. Unfortunately the people around here that are selling do not. I see idiots posting used stock converters for 2-300.
If 47re's are that cheap.... $ 150 ish then how come most rebuilders charge up to $1500 for a core, a pile of $ on parts I get but close to 25% on top for a150 core is an ouch. Problem for me is 47re for diesel never comes up for sale here, core or useable
It's because we want our core back! Believe me, we don't want your money, we want a serviceable core back to build for the next guy. Dealing with cores is one of the worst parts of this business. I'm not selling you the core, I want it back. It's a deposit that's on the steep side so you don't sit on it. Most guys are pretty motivated to get their $1200-1500 back. I have a list of orders that require the timely return of that core so I can get it built for the next guy.
And I'm not sure why everyone is so spun up about what I'm paying for 47RE cores. It's not like I'm calling up the local wrecking yard or shopping for them on Craigslist. As a shop owner that specializes in diesel transmissions, I get at least one or two guys a month that call me up, or stop by wanting to know if I want to buy this core or that. If I'm in need of one, I'll pay up to $150 for a 47RE with a converter. Most guys take it, but some don't. Doesn't matter to me. I have a ton of 47RE cores, so that's all they're worth to me. On the flip side, I'll pay $400-500 for a good late-model 48RE core with converter, and sometimes even more for a good 68RFE, late 5R110, late Allison, or 6R140.
@Dynamic I've been a mechanic for 30 years. I understand why core prices are what they are. I have bought parts that cost less than the core charge. I think it's great when someone like you can get the cores that you need for a reasonable price. It helps keep your business moving. I am not complaining about what you pay for cores but I am jealous. If i can find one for $200 or so I'll jump on it. If not I'll wait. Around here demand seems to be greater than supply so prices reflect that.
I wasn't so much referring to you. Someone on here was pretty annoyed that core charges were so much, when the cores were a lot cheaper than what was charged as a "core charge".
