- Replies 24
- Views 3.4k
Dynamic 8 posts
Gregturley 6 posts
wil440 4 posts
Bullet 4 posts
Popular Days
Late '99-'02 47's are interchangeable. As long as it has the plastic transducer. You can convert the early metal style transducers over to the later plastic one fairly easily if need be. Just avoid th
Thats right, I just paid 30% in import duty and Vat for the quad and assassin, but it's compound so it would be.. lets say 5k for a trans, 1500 for core, and 600 shipping, $7100 import duty is th
If you're paying more than about $150 for a 47RE (with converter), you're paying WAY too much. A 48RE is a whole different story, though.
I'm looking to buy a core 47re for a 01 4wd. Will be built with a triple clutch converter, billet input and intermediate shafts and aftermarket valve body. What year transmissions will work for this? @Dynamic can you provide any info? I'll most likely be buying a valve body from you and using whatever converter you recommend. This is a long term build with parts bought as i can afford them.
