47re for 2001 4wd
I'm looking to buy a core 47re for a 01 4wd. Will be built with a triple clutch converter, billet input and intermediate shafts and aftermarket valve body. What year transmissions will work for this? @Dynamic can you provide any info? I'll most likely be buying a valve body from you and using whatever converter you recommend. This is a long term build with parts bought as i can afford them.
  • Replies 24
  • Views 4.3k
  • Late '99-'02 47's are interchangeable. As long as it has the plastic transducer. You can convert the early metal style transducers over to the later plastic one fairly easily if need be. Just avoid th
  • Thats right, I just paid 30% in import duty and Vat for the quad and assassin, but it's compound so it would be.. lets say 5k for a trans, 1500 for core, and 600 shipping, $7100 import duty is th
  • If you're paying more than about $150 for a 47RE (with converter), you're paying WAY too much. A 48RE is a whole different story, though.
1 hour ago, Dynamic said:
I wasn't so much referring to you. Someone on here was pretty annoyed that core charges were so much, when the cores were a lot cheaper than what was charged as a "core charge".
I wasn't annoyed just asking the question is all as being in the UK It would cost the earth to send a core back and there is none over here so while I need to do my trans I don't know what to do about a core, I'll probably just do the trans I have
You do get the core charge back when you return your core.
I think the core charge is the least of will440's problem. The shipping and taxes in Britain would eat his lunch.
lets say 5k for a trans, 1500 for core, and 600 shipping, $7100 import duty is then added and it varies as each commoditiy is different but lets say 15%  = 8165 then vat at 17%  thats around 9500,  thing is the core charge would be taxable if it was on the invoice and I'll bet shipping it back would cost more than shipping one here.
Hopefully when we get out of the EU at the end of this month a good trade deal is done
