- Replies 8
- Views 1.2k
Gregturley 3 posts
wil440 2 posts
Octafish 1 post
Bullet 1 post
Popular Days
I have never had the need to use a drill to prime a fuel boss, even on filter changes their is enough fuel in the lines to fire truck up, on initial install I just prefilled the filter housing with pr
What's the procedure ?
I'm guessing just pull the bottom pulley and pump mounting bolts.
Then tilt the pump down to get the drill chuck on the shaft?
Do you need a 3/8" or 1/2" drill?
Spin clockwise?
Or do they make a pulley you can put on a drill and use the belt to prime?
