Seat covers
Put these in today. So far I like them. Hopefully they hold up!
  • Replies 40
  • Views 8.8k
  • dripley had his seat covers embossed with his personal logo.
  • And who says there is a lack of humor on here these days. I believe @IBMobile has a chicken generator of anything at his house.
  • You can post the link. No harm no foul.
Just now, dripley said:
I am not the expert on this sure but is my understanding that the torque converter has to stay locked while the ebrake is in use or you damge things.
The PAC break computer ties in to the PCM and automatically locks the converter when it turns on. Unless I have it turned  off when moving above 25mph as soon as I let off the throttle it activates and locks the converter. It’s made quit the difference in stopping  just driving the truck unloaded around town.
Well it seems you have it covered. You will like it. I gross about 23k with my 5th wheel and am able to come down I40 out of Black Mtn on a 6 mile 6% grade in 4th turning about 2500 rpm and only use my service brakes maybe a half dozen times breifly where steepens to 7%. Not fast but safe.
Edited by dripley
  • 3 weeks later...
Hey @Threadzy, any update on these?  Are you still happy with them?  Did they arrive in a timely manner?  I have a notification that the seller is on vacation and to allow some extra time for shipping?  I still have them in my cart and was going to pull the trigger on them.
imageproxy.php?img=&key=342b0e4372bdc5e01596143749_Screenshot2020-02-27at7_30_15AM.png.9714bd72d430fcf3e273b0d3c1edadad.png
Still very happy. They haven’t moved around at all. I want to say I got them in a week or less. I’ll take another picture later today and post it up. I need to replace the drivers seat belt. Cheapest I’ve been able to find is factory for $250. Not looking forward to tearing the seat apart.
Just now, hdpwipmonkey said:
Thanks for the update.  I think I might get them.
I had to take the handles off the back of the seats to get them on. The outside of the seat back is strong Velcro. So you’ll be pulling while sticking the Velcro together. It’s a tight fit. Be careful if you’re pulling from the back. I made the mistake of pulling on the map pocket and it tore partially. Not the cover just the stitching that holds the pocket on.
This is with no adjustment to the covers.
Wow, those look pretty nice.  Thanks for the updated photo and the install tips.
 I also like me that center console. Could you get into more detail on the install or maybe start another thread on the install? I'd like to have cup holders up there. With a manual trans they're on the floor and very inconvenient.
:offtopic:
I put one of these in.  My trucks not a manual so not sure on the clearance but it don't go out over the seat.  This one's a little on the expensive side but you can find them in the 30s and 40s on Amazon if you search.
:backtotopic:
From the picture it would appear my shifter would be very close to hitting it. It looks like it comes out even with front of the seat. Thats right where my shifter is in 2nd.
1 hour ago, Doubletrouble said:
 I've seen those. I wondered how they would work with a manual trans. I've seen them as low as $28 from overseas.
 Did fit nice? Seem sturdy?
Fits good.  Nice and sturdy too.  Not sure about the clearance for the shift though.  It does come out even with the seat.
Instead of bolts like the original center console has. It uses studs. Width wise it’s the same on the mounting. Length wise it’s longer. The rear studs slide right into the factory mounting holes. I just used nuts and washers for the rear. On the front end the metal framing on the center consul I could’ve just drilled a hole in and mounted it with bolts and nuts . As you can see in the pictures. I kind of did an overkill with it. I paid $200 for mine on eBay. It must’ve been out of a wrecked  brand new truck. Because it was in excellent condition. It still had the plastic film over the chrome handle. They have some on sale on eBay right now starting at around $250 all the way up to $700. If you’re patient you can find them pretty cheap. I put one in my brother-in-law’s truck and we got it for about $200 as well. I still need to hook up power to it so I can use the USB charger inside of it. If you needed more room upfront you could just use the front mounting studs from the front factory mounting. It’s just going to be closer to the backseat. You’ll just basically reverse the mounting that I did.
My seat covers came in today :woot:
Couple of issues... The color in person don't look as bright as it did in the pics on Ebay.  I was hoping they would of matched my trucks paint color better (you can see the difference in the pics below).  I had debated on returning them and getting a different color but I thought "let me just slip this one over the passenger seat and see what it looks like..."  Unfortunately while doing that I pulled too hard in the wrong place and... RIP!  Well, I guess I am keeping them now...  So be careful if trying to match color.  They aren't as bright as they are in the pics on Ebay.  Also, be careful where you pull on them.  Some spots I was pulling with all I had and they held up but this one ripped where the seatbelt goes through.  Don't pull there!  Another issue that I think @Threadzy mentioned.  The openings for the seatbelts don't line up perfectly so they don't self retract anymore but to be honest they barely did before.   I am going to let them sit and stretch a little then snug them up again in a week.  The passenger side one isn't quite on there very good...
The quality and fitment is pretty darn good but are they $140 dollars good?  I think so but time will tell...  Pictures below for your viewing pleasure!
Yes, blue is my favorite color in case you couldn't tell...
Edited by hdpwipmonkey
Sorry to hear you tore one. I know how you feel! They do look really good though!
When working with seat covers it some times helps to lay them out in the sun or inside a hot vehicle.  They'll heat up and have a little stretch and give.
47 minutes ago, Doubletrouble said:
 The blue is a little off but they do look nice. eBay you said? Have a link? Just curious.
Yes. I posted it on the first page.
