Pepsi's modified 1999 Long Term Injector study.
- Replies 48
- Views 11k
pepsi71ocean 14 posts
Evan 11 posts
Mopar1973Man 5 posts
Dynamic 5 posts
The transmission doesn't know about, care about (unless it's slipping), or have the ability to sense how much power is coming from the engine...or Smarty settings, "TM" settings, timing adjustments, f
The fluid path to (and through) the converter is the same in forward and reverse. There is quite a bit more line pressure in reverse that in forward, but the charge to the converter is regulated at ab
Both the TV lever and the Gear linkage came loose, it was very odd. SO a PSA Drain your tanks. I installed this drier into the air compressor system and it was the best thing I ever did.
Hey Guys, as you know I'm one of a few guys running a modified truck around here with larger injectors popped to 322BAR. So far the truck is running 100HP injectors a Dynamic Valve Body, and a Smarty. Current Smarty Settings are SW#7 TM3, T3,D4. The truck runs fairly well, and there is no smoke unless you really try. Even so its a light haze when passing.
Ive played with the Timing and TM settings, and can say both have caused stalling issues at varying temperatures. However the stalling is alleviated significantly when you put the truck into Reverse for 30 seconds, then drop it into gear.
I have over 2,000 miles now under my belt with these injectors, and have determined that depending on what settings you have on the smarrty it also effects when the truck won't start due to cold temperatures. On the current settings the truck will not start at about 22F without grid heaters. It will crank over and miss like its got air in the fuel. However 30 seconds with the grids and it fires right up.
