Titan XXL 55 gallon fuel tank
- Replies 11
- Views 6.2k
AH64ID 5 posts
Me78569 3 posts
dripley 1 post
pepsi71ocean 1 post
The wife is sending me teaser pics...
I can hear my wife now when I am installing it " you're gonna make me pee in a bottle just to see how far you can drive without stopping" me: "you know it"
That's one of my pet peeves with new trucks. My new GM half ton has a 90 liter tank. I don't like stopping for fuel when the only reason is my tank is empty. It's sure nice to spend more time on the r
Well I broke down and ordered a replacement fuel tank for my truck. I got a decent price with free shipping and military discount.. but it's still OUCH. Thank you tax return.
I didn't think that 3 fewer gallons would be noticeable, but let me tell you that it really is! I'm not quite sure what Ram was thinking here.. but I gather it's fixed for 2020 with an optional 50 gallon OEM tank.
Towing last summer I got ±.5 mpgs as my 05 did on the same roads/speeds but found myself needing to get fuel in remote towns to make it between big towns...inconvenient and got me thinking about a larger tank. Hard to justify the cost just for this thou and it takes along time to pay for the tank at $0.30/gal different.
Then I went elk hunting and the '18 sure does drink a LOT more fuel at low speeds than the '05... nearly double. I averaged just over 7 for the duration of the hunt vs ~10 in the '05, I was getting around 4 on the drive out vs 8-9 on the 05 (23K GCW on slow dirt roads). I attribute most of that to the auto and an unlocked torque converter. I ended up adding 15 gallons from cans and was still nervous on the drive out. So I decided I would bite the bullet this spring and get the 55 gallon tank. 23 extra gallons should be plenty!
It should be here sometime soon and I'll likely install it as soon as I burn thru this current tank of fuel.
I'll make sure to post up some pics of the install and before/after ground clearance changes. With the skid-plate it should hang about 2.75" below the stock tank.
Edited by AH64ID
