So, I need a little help dialing this tune in, got new upgrades so now she needs to be fine tuned again. My mods are head studs, 100 hp injectors, 62/65/12 turbo, AFE intake, 4" turbo back exhaust, airdog 2 4g 200 gph ( paid like $100 for it so couldn't turn it down haha), 3rd gen stockers on 275/70r18s, and it's got a 3.55 rear gear. I'm getting a bucking/hopping feeling at cruise state and I've tried to tune it out but cannot for the life of me figure it out, any input is more than welcome.alsoi uploaded my current tune
  • Replies 10
  • Views 1.7k
  • My truck liked more timing at 2k than you have.  I would bump your 2k timing to 18-19* and see what happens.    When it hoppes what engine load are you at?   That will tell us if the quad is
  • Let it knock lol.   My truck rattled pretty dang good, but it like to sit at 20* of timing at 65 mph under light load.   Vp's knock, like it's their job.   i'd adjust timing to be
Starting from bottom up.
Boost scaling is correct.
Pump low boost Scale push that up to 10 PSI you don't need wire tap as low as 2 PSI.
Minimum pump tap fueling set that for ZERO %
TPS Min is OK
TPS Max OK
Wire tap fuel 1,600 is OK.
Cant see light throttle timing - 3* (this will get you to 19* at 2k)
Low pressure timing reduct set for 5* (50% scaling makes this actual 2.5*)
Reduct scaling 50% (This will get you back to advance timing quicker.)
Max load offset 1* is good for empty truck but loaded you might need 2 or 3*
Max on the timing should be brought down some. This is not what most think. This is the max you can get while in cruise state. You can force the Quad to dump cruise state when twisting high RPM's.
What RPM is it hopping at?
20 minutes ago, Threadzy said:
Does it do it on level 0? Factory tune.
Lol...... Good question
It's hopping between 1800is and 2000
Light throttle is set at 1.5
When it hoppes what engine load are you at?   That will tell us if the quad is in cruise state timing or if it is using performance timing,
When it leaves cruise to performance timing.... So like between 27% (limit is 30) to about 35% give or take
It doesn't mind the higher timing, I think I'm just nervous because of the timing rattle that increases with the timing advance at cruise. It's not too bad but being my first diesel to tune and coming from a gasser, the rattle always gets me lol
1500: 14
2000:18
2500: 24
3000: 27
max30
Edited by Me78569
1500: 14
2000:18
2500: 24
3000: 27
max30
That's funny because I bought a mid injector tune I think it was yours actually but anyways 14 and 18 is what I set it at before I came to check hog traps lol didn't drive long enough after I changed it to give any feedback right now but when I leave if I remember, I'll post up. I'll switch the last 3 maxes also, but earlier I noticed that pretty much no matter what I changed, I still have this damn..... Idk if it's a hop because if half a$$ feels like a fuel miss or something at the same time. So in not exactly sure what to call it but either you or Mike once said that too much timing would be like hitting rumble strips and it's not that violent
Mine only bucks bad about 30 MPH in 4th gear. Every time I went through Council, ID the speed limit is 30 MPH and the engine load is super low but RPM wise I'm right there at 1,200 to 1,300 RPM's and it bucks pretty good. Anything that brings RPM down that low tend to make it happen.
I could downshift one but running 3rd gear at 30 MPH is like 2,200 to 2,300 RPMs for me.
Ok awesome, THATS what I was looking for, that's exactly when it starts it, low rpm at like 50ish trying to speed up after it locks in 4th. I pulled the 35s off and went 275/70r18 which I know isn't that much difference but it helped a little
