My idea of the ultimate towing turbo
- Replies 29
- Views 9.9k
gimmie11s 12 posts
Threadzy 8 posts
dieselautopower 4 posts
Dieselfuture 2 posts
Well i got her all buttoned up and running. Local turbo shop was able to open up my hx35 12cm turbine housing for the new 64mm turbine wheel.... only charged me $40 to do it. First impres
Quick update, i towed my loaded toybox (almost 14k lbs) 6.5 hours last weekend and absolutely no issues. Turbo worked fantastic.. EGTs on the uphill climbs never over 1100 on quad level 3
It spools good, just a bit slower (few hundreed rpms) than stock xh35, I'm guessing has a lot to do with 7x10s and quad tuning. I'm pretty happy with my set up for what I'm doing, some day if I get on
Got some presents in the mail today from the good ol US Postal Service.
I am going to build a hybrid hx35/40. Well.. it'll be mostly HX40 with the only 35 carryover being the turbine housing.
As much as I searched, it just does not seem like there is a reasonbly priced turbo between an HX35 and a 62/68 BW variant that everyone seems to love. As cool as a BW 62mm would be, i just dont need that much turbo, i dont want the added lag, and my truck's primary function is towing my 5th wheel toybox which is around 13k loaded so i need the turbo to spool reasonably quick.
I ended up buying what is basically a new, un-assembled complete hx40 without the turbine housing (ill be reusing the 12cm 35 housing).
Specs:
--10 blade 64mm hx40 turbine
--60mm billet hx40 compressor
--new center section
--new compressor housing machined to match the billet compressor
I just dropped off my turbine housing at the machine shop to be bored out for the larger turbine wheel. Hope to pick it up tomorrow at which point i'll assemble the turbo and install.
Couple pics
Edited by gimmie11s
