Map boost sensor failing edge
- Replies 15
- Views 4.1k
Str86fan 5 posts
Me78569 4 posts
Mopar1973Man 3 posts
dripley 3 posts
Twice now only with the edge comp on getting on it a little goes in to limp mode scanguage says it’s boost sensor code,replace sensor runs fine with the edge turned off or even with it on it runs good until I get on it,then blows the sensor again, weird.
side note I had a 53 block that cracked so I replaced it with a new one,that old engine ran really good with the same edge chip same ecm, wire harness,vp44,sensors swapped over to the new engine,so I didn’t want to blame the chip right off the bat since it worked so well before,any ideas? Thanks
