Had to change things up a bit when my used Hx35 showed up rusted as **** and the wastegate diagram was toast. Was going to be a 62/64/12.  Everything new now. 62/67/12. Will be assembling tomorrow and hopefully installing it.
  • Replies 29
  • Views 10.7k
    Just my lil' HX35/40 (60/60/12) turbo I'm twisting 47 to 49 PSI of boost maxed out with a performance tune. Now my economy tune and level 3 tops out at barely 35 PSI. Shallow fuel map.
  • Dieselfuture
    Dieselfuture
    I see you got an oring machined for compressor housing, good idea. I couldn't get mine to seal until I used some light coat of rvt. Should be a good turbo for you, I'm enjoying mine
  • I’ve read your posts about your turbo specs so I knew I couldn’t go wrong!
Should be a good turbo for you, I'm enjoying mine :thumb1:
2 hours ago, gipperkid said:
Who did the machine work?
The company on eBay I bought it from. The username is bmwracing_6. They are Turbo Lab parts.
Turbolabofamerica....thats who supplied my parts too.  Great guy, Austin.
My billet 60/64/12 just made a 6 hour trip towing 14k lbs without issue.
Love this turbo!
A1891-E8-E-B72-C-4-C9-D-B48-C-63-A10-D31
She’s like a rocket ship now! My son was driving I told him to get on it a little bit. Didn’t have enough hose to hook the waste gate up yet so there’s a little bark at the end. Sorry about the glare.
@ThreadzyHappen to have a list a parts you bought? And a list of the machine work turbo lab did? I may just want to do this as well.
Edited by gipperkid
Just specify what compressor wheel you’re using and they’ll mill the bearing housing out to fit.
50 minutes ago, gimmie11s said:
Looks sweet!!
Thanks I love it!
I heard mixed reviews about them a while back, hopefully they got better over the years.
Hopefully! Time will tell. I’ll keep everyone updated.
It will be fine.  The parts turbolab sells are quality parts.  Ive assembled 4 turbos from him in the past 7 years and EVERY one of them is still going.
It would be good to have your turbine and compressor wheels balanced before you assemble though, just to be sure.
I had that done on mine when i had them open up the turbine housing.
 That’s good to know!  I didn’t have the wheels balanced because I thought they already were. I saw balancing marks on the turbine and compressor wheels.
Correct but they (turbine and compressor) are each individually balanced.
The turbo shop will assemble the turbine and compressor together with a locknut and balance all 3 as a unit.
Well sheet! Is this going to ruin my turbo? Should I pull the cartridge back out and have it all balanced? Or will I only get 50,000 miles out of it instead of 100,000? Was yours off by much?
Edited by Threadzy
TBH, id have the shop balance them as i described only because the turbo is going to work at 30-40 psi or more.
If you planned to use it on a gas car at lower boost (25 psi or so) then i wouldnt worry about it.
Just my opinion above..... who knows, it might last a LONG time the way it is.
Like for me I had my stock HX35W eat a hose clamp I sent it out through DAP to Industrial Injection for rebuild. It cost me $800 dollars for replacing a compressor wheel and the rebalance. They reused the turbine and the housings. Still in all I think I got hosed on that deal and could of upgraded for less.
That does seem pretty pricey. I’m in the process of talking with Turbo lab directly about a balanced rotating assembly.
Ive found that the big name diesel shops usually over charge for some of the bigger items (turbos as an example).
Did you end up running yours as is, or what's the plan?
