Code 0237,0112,1475,1689
Just put in a new fass lift pump and vp44.
have no power.
Wont rev above 2250 RPM in overdrive
will rev to 3000 RPM with out overdrive.
really slow to get up to speed .
Not a lot of cash left to throw at the  old girl.
heart broken to see her sittin there
  • Replies 52
  • Views 9.3k
    No. It takes everything I got to just pull the shaft over the wastegate arm. It heavily sprung.     No. P0237 code is a lo volt code for the MAP sensor and has zero to do with the was
  • I agree with Mike. You can put air pressure to the waste gate to move it.
  • dripley
    dripley
    I use straight pins for back probing connectors. You can get them with plastic balls on the blunt end so there is no metsl to metal contact with each other. They are a lot easier to get into the conne
Did you clear the codes before the VP install and these came up afterwards? What you describe is very much like your MAP sensor has failed.
Thanks for your feedback
i did clear the codes but come to think of it not after replacing the vp 44.
My code reader doesn’t work on my truck.
i had a buddy help me out before.
But with this Covid-19 I feel bad asking him to help out again.
Any advice on a cheap code reader/clearer that I can order from eBay or Amazon??
OBD linx lx or mx are pretty popular. You would have to google it. Most auto parts stores here rent them, not sure in your location. I just replaced my VP back in November and the MAP went with it.
Thanks man
this means a lot to me.
i have a lot of checking to do.
i will be in touch when I figure this out or need some more help.
much appreciated
Should I be able to move the waste gate by hand??
i got on the ground and reached up from the bottom and with a 13/16
wrench on the waste gate and tried to move it.
it wouldn’t budge.
could the waste gate be stuck open.
The truck wouldn’t build boost then would it???
could that give me the 0237 code???
i am just a novice
what do you think?
No. P0237 code is a lo volt code for the MAP sensor and has zero to do with the wastegate.This is a sensor or wiring issue.
Need 20 psi or more to move the arm.
Yes I think I am up for a new map sensor.
owe just cleared the codes and ran the truck.
only 2 codes this time.
0112 and 0237.
Would I need to replace both sensors to get the truck out of limp mode.
OR
could I get away with holding off on the IAT for a little while??
short on cash right now
Thanks so much for all your help
0112 and 0237.
Not a sensor problem normally... Check the OBDII codes
Will your scanner read the data from the sensors? When mine with the 237 the never changed while driving. I did not have the 112 so it could a problem in 5v supply issue as @Mopar1973Man is saying.
No the scanner doesn’t read the code when driving
I am speaking of the data from the sensor and not codes from the computer   My scan gauge II will get a pressure reading from the sensor while driving. The numbers don't mean much  just that they are changing as you throttle up and down. When mine failed the reading did not change.
Yes I am aware that’s what you mean.
my buddy said we can try that this afternoon.
thanks again for all your help.
i will update you on our progress
Yes it was as you said.
went around the block and no change in the pressure reading.
101 kpa.
that makes me feel better.
the readings are there just not moving.
the new map should fix that.
knock on wood
LOL
Before buying a new MAP sensor, try pulling it off and spraying some wd-40 inside to break up some of the carbon and grit that may be in there.  Use some compressed air to d0uche it out real good afterwards.  I believe its a deep 30mm socket to get MAP off.
Worth a shot before spending $$.
Edited by gimmie11s
correct spelling on "believe"
Yes I tried this last night.
the sensor was spotless.
I did find the map sensor online for 15$ US.
so I ordered 2.
With shipping 53 US$
about 70 Canadian.
I may have to buy the adaptor cable???
thats about 80$
So all said and done about half price as what I would pay at Cummins.
OR 1/4 the price of the dealership.
thanks for your help
i will let you know when I have the new parts are installed and how it worked with the issues I’m having now
What kind of MAP sensor did you find for 15 bucks? And an adapter for 80? Thats the opposite of any I have ever found.
Friday parts . Com
p/n-4921505 that’s their and Cummins P/N
and the dealer / Chrysler sells the adaptor for
around 75$
Check it out and let me know what you think.
I just goes to show you how much people mark things up
