- Replies 17
- Views 3.7k
Gregturley 7 posts
Mopar1973Man 5 posts
Me78569 4 posts
Quadzilla Power 1 post
Popular Days
Quadzilla high idle only worked on lvl 0 within the code. Or if the power bar is green for being colder than warmup temp setup.
Ok I'm an idiot. Went to the truck at lunch and checked the Quad. I turned power level to 0 this morning when i did my WOT run. Thought i put it back to 3 afterwards but it was still on 0.
All good... No problem that why we all come here o hang out is to help out with all problem regardless if they seem foolish or stupid. We all learn from each others mistakes and ideas. Don't sweat it.
If this is in the wrong place sorry, please move.
@Mopar1973Man @Me78569 @dieselautopower
Quadzilla Adrenaline V2 has started kicking on high idle when its past the set point of 160°. Engine temp on Quad and autometer both show 180+ and it will turn on. If i turn off high idle in settings it does stop it from turning on. This started out of nowhere about 3 days ago. I left it off overnight and it worked correctly for 1 drive then this morning started doing it again.
It has also started displaying the wrong gear. Driving with shifter in D it will show 1,2,3,4. As i come to a complete stop it shows 4,3,2,1,3,4,L. Shows L until i start moving again. In P,N,R it shows L. It was always pretty accurate before 1-1 1/2 weeks ago.
I reset the vehicle selected and reset all settings with no change.
I had made no changes to anything on the Quad before these issues came up. Would reflashing the Quad help? Can i do this myself?
Edited by Me78569
