Seat Cushions
Can you use a pass. seat cushion on the driver side with very little mods? I realize the seat part #'s are different, but can they be made to fit?
  • Replies 11
  • Views 3.5k
  • Remove the 4 nuts and swap them. Nothing to it. My passanger only lasted about half as long as the drivers seat. Different material on sides.   No mods necessary.
  • Royal Squire
    Royal Squire
    Sorry @Blueox01 I was in a hurry
55 minutes ago, Royal Squire said:
Yes
Please don't explain to much. :shrug:
No mods necessary.
Edited by dripley
Not much to explain, Did this on my truck. remove passenger side > install to driver side.
Okay, I thought they had different part #'s. Thought I looked at it before and holes for the spring didn't match up, my spring is broken also.
they are different slightly, but it is easy to come to terms with the differences if your drivers side is bad enough.
Just swap them. The passanger is better in a way. It throws you more right than left.
