- Replies 11
- Views 3.5k
Ralph_5.9 4 posts
Mopar1973Man 3 posts
Tractorman 1 post
Great work! 1 post
Popular Days
You will probably hear different opinions about pilot bearings / bushings. My original clutch replacement was at 297,000 miles due to a OEM pilot bearing failure (needle bearing style). It caused so
Bushing or bearing both have pros and cons. Bearing better performance less fault tolerant. Bushing better fault tolerance less performance. The 6 speed is already stiff to shift and hard on syncros s
Well guys, it’s time to change the clutch in my 02 with 103k on it. It held all last summer until I got it to slip up hill in 6th with the quad on level 6. This truck is a summer driver/toy that I plan on building to around 500-550 hp. My brother has an 01 with this clutch https://www.dieselautopower.com/1999-2005-cummins-nv5600-13-x-1-375-single-disc-performance-replacement-ceramic that I’m also considering. However, i’ve read that a factory replacement pilot bushing may be a better option than the bearing. I’d hate to have the bearing fail and pull the trans again. Thoughts on this? Also as far as the flywheel goes, would my best option be to just get it resurfaced? First time doing this job so all advice is appreciated.
