- Replies 12
- Views 2.3k
Towrigdually 5 posts
Gregturley 3 posts
Russ Roth 2 posts
IBMobile 1 post
Yes I do. Go rent a pressure washer and put it in the bed. Then drive until you have to slam on the and the pressure will knock them both into the front seat. Thats only time I had mine out. All
$45, no brainer, let them do it. If they break it or it leaks they own it.
Well that’s fun. Guess it’s just gunna go to the shop for both R&R. Let them deal with that mess.
Pretty sure I’ve narrowed it down to the window seal leaking and thats how water is getting in the cab. On the back seat and window. But only when it rains hard.
ive resealed the 3rd brake light and cab lights with silicone, new door seals, window seals, windshield seal, cab seals, and quad cab door seals.
has anyone removed the window? I found a seal online but have no idea how to remove and replace.
Edited by Towrigdually
