- Replies 28
- Views 7.5k
JOHNFAK 10 posts
AH64ID 5 posts
Mopar1973Man 4 posts
Rogan 4 posts
Hey guys
Trying to get my tranny cooler installed this weekend.
On my auxilliary cooler - it has 2 wires , about 9 inches each - 1 black and one blue. It just says to connect this to a switched 12V power supply.
How do I do this ?? Never have before.
I assume I could run 1 wire (blue) +ve terminal and 1 (black) to negative terminal - and it would get power every time the engine started - but I would prefer to activate via switch - ideally something like the existing A/C switch.
Is it easy to hook up to the A/C switch somehow so when I turn the A/C or FAN on - it engages the fan on the auxilliary cooler ??
OR seperate switch from o'reilly's/electronics store ??
Need full details - and quite basic details - not overly good at reading wiring diagrams etc
thanks guys
Kinda thinking I need to not install the thermostat - as it kicks in at 180 and I might want to start cooling a little lower than that. (As if I am 180 on COLD line where thermostat is - then I am 220+ on HOT line out).
So then I am thinking I could use some sort of 12v toggle switch with inline fuse in the cab ?
So - can I tap into an existing 12 V wire and then just run the black wire to a ground - or do I need to run the black wire all the way back to the negative terminal ?
If I can tap an existing wire - any ideas of best one ? Easiest to locate and splice ? Or should I run it from the bagttery direct ?
