Engine surging... at a loss here
- Replies 18
- Views 6k
jimbochilds 7 posts
Mopar1973Man 3 posts
Tractorman 3 posts
dripley 2 posts
Mike, The FRRP does not "dead head". It has an internal regulator that returns the excess flow above which is needed to maintain the set pressure to the inlet of the pump. It works similar to
I'm new to posting here, but have been reading tons of threads, suggestions, and related story issues here over the past month and a half. I am working on a friends 01 that I cannot seem to get figured out. This started for him last fall with the truck having dead pedal issues, stuttering/miss, and a small hand full of codes. I unfortunately don't have those codes to reflect on now, but the agreed upon synopsis was that the VP44 was on its way out so we made a plan to attack it this spring. Back in April I installed a new VP44 from Bluechip Diesel along with the Airdog FRRP lift pump. At this time I also installed 2 new Interstate Batteries. The truck fired right up and ran like a dream, in the driveway. I let it good a warm before taking it out for a test drive, and that is when the dreaded problem showed its ugly face and I CANNOT seem to bring resolve to it. Heading down the road it ran like a dream for the first half mile, then it went into this weird buck/surge/sputter thing. It did die once and was puffing blue smoke--bad. I got it back to the house and started trying to figure it all out. I put clear fuel hose in the system to watch for air bubbles. Nothing. Checked the plugs on the pump and even pulled the nut and checked the key way position, which was good. I also checked the seal washers on all the banjo bolts and the fitting on the back of the head, which were good. I had 3 codes; P0216, P0230, P0122. I cleared those codes and tried to drive it again. Again it started and ran beautifully in the driveway, but once heading down the road, trouble. The good in it was the codes did not come back.
Next I chased all the grounds and even did the ground mod mentioned several times on this site. Had the alternator tested at two different parts stores. That checked out good. Again the truck fires right up and runs like a dream in the drive. Idles perfectly, revs up and will hold steady where ever i put it on the tach. No hiccups or any funny business. Start to drive and the gremlin comes out. This time I made it about a mile and a half before it starts acting up. If I hold my foot steady on the throttle it surges/sputters/ puffs bluish black smoke and acts like it wants to die. Sounds like a two stroke boat motor is the best sound explanation I can come up with. At the end of this round of troubleshooting and test drive I come up with a P1689 code. I took out the fuel system relay and checked for a good ground there on pin 85. Again I checked the alternator for A/C noise and had a .025 reading so think that is within limits of being good. I have cleaned all the battery clamps/cables and connections for corrosion with baking soda and distilled water. Checked and rechecked grounds. I pulled the ECM and cleaned the contact points on both the box and the engine block to ensure a good clean contact ground. No Change.
Yesterday I had a friend come over who has the same essential truck (2001, 2500 Automatic Trans, 4x4, etc) and I put the ECM out of the problem truck into his truck to verify my suspicion that the ECM had to be my bad/weak link. I struck out on that one. We ran/drove the truck for a half hour and could not duplicate the problem. After that I reinstalled the ECM back into the truck and tried to drive it only to have the same results. This time I got a CEL and the code was P0122. I cleared it and drove it again and it didn't come back on. I have done the APPS reset (pressing the pedal and releasing slowly) each time I have had the batteries disconnected. I am at a total loss here at this point.
I should mention that the truck has a couple ABS codes (67 Pump motor circuit open and 65 Internal main relay open) and the owner told me last week that he had new 100 horse injectors put in about 5 years ago. Could this be a turbo waste gate issue or maybe bad o-rings on an injector or connector tube giving me these fits?
ANY help is greatly appreciated.
Jimbo
