Please help stranded no electric power
- Replies 13
- Views 2.9k
JAG1 6 posts
WiscoRedkneck 4 posts
Mopar1973Man 1 post
Hawkez 1 post
Start simple double check all your battery terminals for being clean and tight. Then move on to fuses. Double check all the fuses to see if any fuses blown. All your fuses should be under the hood.
Why don't you help keep the site running so your not an expired member? You can donate just a small amount and it really helps. Next time you will get more response as a member too. Just d
That's Otis a 30' crane barge we use the crane to break ice then the flat deck follows behind All home made using a old weed cutters hull for the base
I'm stuck probably going to need a tow.
Here's the deats
03 3500 dually mostly stock besides air cleaner muffler delete.
Problem started as slow cranking condition so I replaced the batteries and got no where come to testing the starter I find that to be over drawing.
Went to make it home so I tried to restart the truck. Long short cranked super slow then I heard a pop and the truck is completely dead red light on the dash ( it's on the upper left side of the coolant temp gauge)no interior lights no nothing.
At this point I have verified voltage at 13.45 even on both batteries checked the fuses to find again no resolve at this point for the last 1.5 hours the batteries have been disconnected to attempt a security rese but at this point I am so stumped and stuck heck I can't even put the windows up. Just reconnected the batteries still no luck.
Please help
Edited by WiscoRedkneck
More specific information
