- Replies 13
- Views 2.7k
1369x 4 posts
CUMMINSDIESELPWR 3 posts
Haggar 2 posts
NIsaacs 2 posts
Been awhile since I updated but trucks been back together with the new superstick nv5600 from Cody I absolutely live it finally picked up my new 40 foot trailer as well and am ready to start hauling c
Wow, That is spooky! Glad you are OK. It is a tough call. I would check differential first. It would be easy for one little piece to be wrong (broken tooth, Spider gear axle retai
I was coming home yesterday towing my trailer and a car on it cruising at 70 mph in cruise all off a sudden the rear tires locked up and I skidded to a stop leaving a nice long set of dually tracks on the road. Luckily I wasn't on to big of a highway. Anyway initially I thought rear end was locked up but that's not the case. The trucked would not pull forward at all, but when the roll back pulled the truck backwards it rolled smooth and then when he pulled it forward after pulling it backwards it pulled fine no issues. Unloaded the truck and I drove it into the shop. Now I haven't broke into anything yet the driveshaft doesnt seem twisted all the u joints are still tight and I felt no issues with the rear pulling into the shop. However the trans is extra clanky right now and I dont wanna run the truck long. Any help would be appreciated if anyone has had problems like this before. And on a scale of 1-10 how likely is my nv5600 **** and who is a reputable rebuilder or place to buy a reman thanks.
