Quadzilla stumbles @ max TPS WT %
- Replies 106
- Views 18.1k
rogerash0 44 posts
Me78569 33 posts
Mopar1973Man 22 posts
dripley 3 posts
you felt it get weak after 2800 because of lack of timing. You should have a good hard pull to 3500 rpm. The VP is starting to fall off beyond ~3250 rpm but it is still able to do 600
Because level 2 cuts CANBus and limits to 100% cuts off anything above 100% fuel map. I've ran never had one issue with Edge Comp for over 10 years on 5x5. Then running Quadzilla o
the reason we dont cut canbus on levels 4-xx is a good tune shouldnt need canbus to be cut. canbus fuelig should be smooth and easily controllable with the right foot. Wiretap is not easily control
Am I the only one who has a quad that makes the whole truck stumble, buck and shake like the VP is emptying when the throttle reaches the % you set max TPS to? I'll still have 10psi of fuel on the mechanical gauge right before the VP and after extensive test driving i worked out that if my throttle applied percentage equals or exceeds the max TPS it acts like the truck is running out of fuel. Lots of smoke ensues and it cuts out and bucks. I see 2.8.4 ADR is still the latest version. Am I the only one?
I'm running aggressive settings without min of 32% max of 40, 50, 60, and 65 as a final setting so the truck doesn't fall on its face. Boost scaling is 20psi, 2100ms (it stumbles and does the same out of fuel fit if I use 2200ms), 150% fueling from 6psi on up.
200hp f1 injectors
62/68 .70ar
475/96/1.32
New Industrial Injection SO VP
New head gasket and no boost leaks, makes 60psi max. On the street 42psi is usually the most I see because I can't play in overdrive without speeding.
Airdog 4g 200 with sump and full gas tank. New filter and water seperator.
I have a drive pressure gauge, s475 boost gauge and an overall boost gauge. Drive is 2-3psi less than boost until 60psi has been sustained for a few seconds, then drive climbs to 80psi eventually (on a 100mph pull).
Edited by rogerash0
