Quadzilla stumbles @ max TPS WT %
Am I the only one who has a quad that makes the whole truck stumble, buck and shake like the VP is emptying when the throttle reaches the % you set max TPS to? I'll still have 10psi of fuel on the mechanical gauge right before the VP and after extensive test driving i worked out that if my throttle applied percentage equals or exceeds the max TPS it acts like the truck is running out of fuel. Lots of smoke ensues and it cuts out and bucks. I see 2.8.4 ADR is still the latest version. Am I the only one?
I'm running aggressive settings without min of 32% max of 40, 50, 60, and 65 as a final setting so the truck doesn't fall on its face. Boost scaling is 20psi, 2100ms (it stumbles and does the same out of fuel fit if I use 2200ms), 150% fueling from 6psi on up.
200hp f1 injectors
62/68 .70ar
475/96/1.32
New Industrial Injection SO VP
New head gasket and no boost leaks, makes 60psi max. On the street 42psi is usually the most I see because I can't play in overdrive without speeding.
Airdog 4g 200 with sump and full gas tank.  New filter and water seperator.
I have a drive pressure gauge, s475 boost gauge and an overall boost gauge. Drive is 2-3psi less than boost until 60psi has been sustained for a few seconds, then drive climbs to 80psi eventually (on a 100mph pull).
Edited by rogerash0
  • Replies 106
  • Views 20.1k
  • you felt it get weak after 2800 because of lack of timing.      You should have a good hard pull to 3500 rpm.   The VP is starting to fall off beyond ~3250 rpm but it is still able to do 600
    Because level 2 cuts CANBus and limits to 100% cuts off anything above 100% fuel map.     I've ran never had one issue with Edge Comp for over 10 years on 5x5. Then running Quadzilla o
  • the reason we dont cut canbus on levels 4-xx is a good tune shouldnt need canbus to be cut.  canbus fuelig should be smooth and easily controllable with the right foot.   Wiretap is not easily control
Or there isn't enough load to build boost and the converter is just being blown through until lockup.
Never thought of that but very possible. Transmission temps should spike quickly if so...
Bottom of third to top of fourth is a full pull in my books. I did a plethora of them on the highway with the 220hp injectors and weepy head gasket on the way to d&j. Thr back end stepped out once on a damp surface. Itll make 60psi if i do that pull but ill be going 80-90mph by the end of it. Once it goes into OD with the tc locked you feel the torque come on proper.
I don't have a good place to do a high speed run like that around here.  20mph over the limit is reckless driving in VA, too.
I could potentially get on the interstate when traffic is low and try it, but I'd still be speeding.
My coolant to tranny heat exchanger is gone. To cool to trans I have the rad up front and a derale under the bed with the fan not turned on because I never break 160-180*F in daily driving. With the slightly lower than stock stall DPC converter from firepunk it would heat up a good bit more.
With the 150rpm lower than stock stall, the .80ar housing and 220hp injectors the truck was like a drag truck. Smokey and then if I got on it hard enough to spin it to 2k rpm and above to clear the smoke I was rocketing. Thats what prompted me to goto a stock stall was to keep smoke down, same with the .70ar housing.
Edited by rogerash0
It just seems htat you should be making that 60 psi way lower in the rpm band.  I will try and dig up a data log from trevor ir tyler.
So it may be a thing that small compounds on a vp truck can blow thru a stock stall converter? New cummins Map Sensor shipped today. My truck probably makes 40psi at 50% tps at 3k rpm in 3rd gear, even today with fueling turned down to 125% max from 10 psi on up, tps min 0%, tps max 100%, min wire tap fueling at 7psi, min wire tap 0% and your timing.
I have some like new toyo 35s that will add a lot more load and gearing. I could throw them on.
Be aware of your final ratio... it will load it up more, adds more stress to the transmission, and higher EGTs. Im finding optimal ratio right around 3.42 to 3.73. So like 285s on 3.55 gears makes 3.42. Now 245s on 3.55 is 3.69. But go to 35 inch on 3.55 will be 3.21. This might be too low of a ratio number.
I am really not sure, all i know is looking at your data logs I think your boost according to the ecm is not coming on fast enough compared to other 62/75 twin setups.    I would expect to see 20+ psi by 2k rpms with the fuel you have.    having only 10 psi at 2k rpms means the ecm is not fueling hard.
look at my data logs and see how my 30 psi setting of %120 help fueling at max until over 3k rpm.   I was at WOT thought.
I would ensure you are on lvl 3 only, and from a stop go straight to WOT while data logging.  Pull to 70mph is possible wihtout lifting and post the datalog.  I would expect boost to climb to 50+ psi by the end of 2nd and have it hold or increase throughout 3rd and od.
Here is another datalog of mine of a Wot to 70 + mph
Note how canbus (green bar) peaks at the end of 2nd and pretty much holds peak at 4095 until the end of the pull.  also note how boost peaks ( middle blue color) and holds at ~36 psi from the end of 2nd on as well.   again this tune started at %68 canbus at 0 psi to 120 at 30 psi with no wiretap.  I was hitting peak duration and holding.
If you look at the log I posted earlier of your run your canbus falls off as rpms raise,  this tells me 1 of 2 things or both it causing it.  1. tps is to low for the ecm to think you are driving hard, 2 boost is too low for the ecm to be fueling hard.    I know for a fact that upper end duration is being lost due to not enough tps input.  but the 1800-2400 rpm region might be a combo of both.
Edited by Me78569
I've ran the 35s for awhile and towed with them, so I know it loads it down a lot. I have them, so it is what it is.
Me - I read what you said. I can do the WOT pull you asked for to 60mph probably.  Whats the minimum fueling you want me to use? I don't want to die. Min fueling of 90% and max of 120% okay? With 1200us wiretap or no wire tap? I don't think I've ever floored it since I got the big injectors. Every time I went high high tps, I hit my tps max setting and it smokes and falls on its face like the original post was about. But ill set tps max for wiretap at 100% so hopefully that doesn't happen.
Run this tune and go WOT from a stop on lvl3.  lvl 3 does not use wiretap.  we are just looking to figure out if you are getting full fueling at WOT and looking at a WOT data log.
Once we are happy with how it runs without wiretap we will talk about adding wiretap in.  for now no wiretap.
Power Levels: 6
Fuel Load timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 19
2500: 25
3000: 29
Timing Max: 30
Pump Stretch: 2000 microseconds
TPS Pump max: 100%
TPS Pump Min: 0%
Pump Low Boost Scale PSI: 10
Boost Scaling: 40 PSI
RPM Limit: 3500
Power Reduction: 10%
0 PSI %: 76
1 PSI %: 77
2 PSI %: 78
3 PSI %: 79
4 PSI %: 80
5 PSI %: 82
6 PSI %: 84
7 PSI %: 86
8 PSI %: 88
9 PSI %: 90
10 PSI %: 92
11 PSI %: 94
12 PSI %: 98
13 PSI %: 100
14 PSI %: 102
15 PSI %: 104
16 PSI %: 108
18 PSI %: 112
20 PSI %: 116
22 PSI %: 120
24 PSI %: 124
26 PSI %: 128
28 PSI %: 132
30 PSI %: 136
Dang man thats gonna be scary. Its late and it cooled off. I could go out now. Nee senslr gets here next Weds or Thurs. You want the data log off that pull?
It shouldnt be scary, whats the point of ponies if you dont use them.
But yes datalog.
Lol 50% tps and she's normally making max ponies. I havnt used 100% pedal in ages .
It was already after 9pm and im in a cul-de-sac where everyone can hear the beast start. So I'll see about running it tmrw.
Edited by rogerash0
The idea with a proper tune is that if you go WOT you are throwing the right amount of fuel at the truck so you ramp up fueling smooth and steady.   Throwing a ton of fuel at the truck isn't actually faster, but torque comes on more like a light switch rather than ramping up.
Here is an old datalog where I setup 2 tunes.  1 perfectly clean, 1 using %150 settings across the board.  Both were snap to WOT from 0 mph to 60 mph.  You can see that the blue bar graph ( overfueled ) ramps up to peak right away, where as the green one ramps up slower, both peak fueling.  However if you look at the boost and mpb lines they follow each other without one standing out.
over fueling != faster lighting turbo when talking about normal sized turbos.  Your 62 is a normal turbo.
Quote
I ran a test yesterday comparing my daily tune to a stupidly aggressive tune set at %150 duration from 0 psi to 30 psi.   I wanted to know if there was a significant difference in power between a clean tune and an overfueled tune.
You can see the huge amount of fuel down low.  However most everything else follows each other.    Both reach 60 mph at pretty much the same time, both have about the same egt's and both build and hold boost exactly the same.
The overfueled tune did feel more responsive when not at WOT, but that was simply because I didn't have to push the pedal down as far to get the same seat of the pants results.
Edited by Me78569
Yup right there... Overfueling tunes like Smarty tend to make the APPS value hit max duration at mere 40% APPS or so of throttle. Where a proper tune uses the full 100% of APPS to control fuel. I checked over my tune and with my economy tune (123%) max I hit a full 4095 CANBus fuel with WOT of the APPS. Haze to light smoke is acceptable but heavy smoke is not going to build power any faster. Some of the smoke you can tune out with timing. Even the stock ECM software (without a tuner) can hit max fuel 4095 CANBus fuel at WOT just the timing is rather retarded.
Blue bar is canbus OF for over fuel. How is that actually calculated? I understand it's more light switchy, thats kinda common sense, but my from my angle if she will take the fuel and burn it, I want to give it everything she will take to reduce the amount of time it takes for maximum power. Thats for a max effort tune, atleast. Im general what im getting at is perhaps in a race (not that I race) you could shave 1sec or a half sec delay/ reaction time off by making it fuel harder/faster. Unless when u floor it the ecm really has no different reacting time to the fueling, you just have more resolution in the fueling from the pedal and the tenth of a sec difference from half throttle and max throttle when flooring it
As long as the Quadzilla is displaying 100% Engine Load or 4095 Fuel Number then its maxed out nothing more can be done. The rest of the time is based on how long does it take to spool the twins turbos your running. The boost number is what is unlocking the tune to fuel more with the wiretap. I would be looking at how much retard at the hit of WOT. This is what builds boost quickly. @Me78569 tune is starting out at 16* which is pretty tall amount at 1,500 RPM you'll have to play with the reduct settings and see if you can dip the timing down quickly build boost and pop back up on top with full advancement. This will take a bit of the time out.
