- Replies 10
- Views 7.2k
Mopar1973Man 4 posts
BennyGGG 4 posts
Haggar 1 post
Dieselfuture 1 post
Yeah the manual only talks about the fronts. If I picked the part correctly that is an M14 bolt. (06504691) It looks like it says 10.9 on the head in your picture. Th
I always just got them snug, if I had to guess 65-70ft/lb
Be careful. I did the front caliper frame bolts in the front with loctite. Needlessly to say the loctite and being torqued in it was so hard to remove I broke 4 sockets just using a breaker bar to rem
Can’t find the torque spec for the rear caliper bracket. 2001 Cummins ram 2500 with ABS and rear disc. Appreciate any help ??
FSM 5-3 is where I was looking. It’s just not clear to me.
