question about w-t ground mod
- Replies 13
- Views 5.1k
dieseldon 6 posts
IBMobile 3 posts
JAG1 2 posts
hdpwipmonkey 1 post
Popular Days
Thanks for the suggestions, I think I will move my fuel pump wire to that terminal! As a side note for anyone that remembers the mystery issue with truck dying when put into gear cold, tod
Yes, that's what is done to address the 12-14 volt charge wire running next to the other ⩾ 5 volt wires. No, not from the alternator. You could just disconnect it form the PDC and alte
Glad you got it all figured out @dieseldon. As far as the extra ground between the batteries, I have not done it (at least not yet) and I have been running like this for about a year without issues.
Sorry if this sounds like a dumb question, I'm doing the w-t ground mod and I'm a little stumped on the alternator charge wire.
Maybe it was explained somewhere but I'm just not seeing or overlooking?
So, we unhook the original charge cable from alternator and pdc and then just have a short cable from alternator to passenger side battery with a fuse/breaker inline?
Question; so no cable gets connected back to the pdc? Why go to the trouble of disconnecting it at pdc and completely removing it? Just cut it and leave it?
Am I missing a step?
Thanks for any help on clearing this up!
