Injector pop pressure and it's affect on mileage ???
- Replies 14
- Views 8.8k
SASQCH 4 posts
AH64ID 3 posts
guesswho512 2 posts
JOHNFAK 2 posts
Injector pop pressure and it's possible affect on mileage is a subject I have not seen discussed on the forum.Does the pop pressure of the injectors affect the atomization of the fuel enough to have a noticeable effect on fuel mileage?I suspect that it does.I'm on the third set of injectors in my truck trying to get a good balance between towing power and economy.I also realize that today's fuel is not as good as the fuel a few years ago.On the stock injectors in 2004 I was getting great mileage. Then I got a set of +80 injectors using the stock ones as exchange. Mileage went way down hill. I have since put in RV275 injectors and gained some of the mileage back but it still isn't anywhere near the original stock injectors.I still have the +80s and am thinking of taking them in and getting them set to the highest pop pressure I can to see if that helps the mileage any.Does anyone know what the pop pressure range for injectors on a vp44 is?
