- Replies 9
- Views 3.5k
elshadow001 3 posts
Mopar1973Man 1 post
ISX 1 post
Prowelder 1 post
Well I have my dashboard patched. I use the Goop again. I worked it in the crack with a razor blade.Let it set up overnight. Then I used my dremel with a soft nylon brush to remove the excess goop off the dash.I drilled through the end of the crack on the front side of the dash to stop it from cracking any farther.I then used a dental burr ( same one I used on my fender ) to open the crack up some but not go all the way through.I used my finger to fill the crack up, and a little above. Then used my razor blade to level it off, and the dremel to smooth and remove the excess on the last part of the crack - well its a break actually.Smoothed it off and then I put a coating of clear pvc pipe glue over the top to add a little more strength, and try to make it acceptable to look at.I will try to get a picture tomorow to add to this post.I know it is not as good as the factory but considering it will be under a cover for the dash it should be ok. The dash now has it's solidity like it wasn't broke at least.Some day you get the bear, and some day the bear gets you. This time I am just trying to recover from seeing my baby with a broken part :banghead:
