01 Rough Idle Then Smooth with No Tach
- Replies 17
- Views 7.6k
Mason The Dev 8 posts
jag 3 posts
dripley 2 posts
Great work! 2 posts
Hi Everyone,
I've got an 01 Drive-train that's doing a weird thing.
First 5 or so seconds, the truck seems to idles a little high, and a little rough. Then it smooths out and sounds like its running fine, but it has to Tach reading. Completely drops to zero, this is consistent. Every time you shut the truck off and restart it, it does this. The tach even reads, while it does read, seemingly accurate. What else has me confused is when I plug the code reader in and go for a drive looking at live data, it also seems to report proper RPM.
I did a cluster test and it didn't seem to have any issues, so I don't think it's a short with the gauge,
the Cam Position Sensor is new, but I suppose could still be faulty.
ECM is reporting RPM to diagnostics, although I'm not positive this data is coming from the CPS sensor.
PCM wire 8 is also sending constant voltage across the wire.
Here is a video of the issue
