Lift pump control guidance
- Replies 4
- Views 1.6k
Dieselfuture 1 post
Royal Squire 1 post
LorenS 1 post
Threadzy 1 post
Approximately a year ago my lift pump(Raptor)quit working because my ECM was misbehaving(WTS light only working part time). I hot-wired lift pump through a switch as I needed truck. I have since had ECM repaired and all is good, however I would like to know what the folks here would suggest I do with lift pump power.
Should I hook it back up to ECM, through a relay of course, or should I use @IBMobile ASD wiring article for lift pump power? I’m kinda apprehensive about hooking to ECM again but that would be simplest.
Thank you in advance for your suggestions.
