- Replies 14
- Views 3.1k
JAG1 4 posts
Tractorman 4 posts
Djordan94 3 posts
Mopar1973Man 2 posts
Since it sounds like everything was running fine before you installed a new lift pump, I would thoroughly recheck your work - especially at the fuel connections. The fuel system may be losing its pri
I think It is Possible John Might be right about the fuel pressure always being positive or always ahead of the vane pump in the VP44. However, we have not seen detrimental effects from pressures high
@JAG1, I very much appreciate your approach for considering a different concept regarding the role of the lift pump in a VP44 system. I always want to give out the right information to the readers, e
Hi all I'm new to the forum and this is my first cummins truck. 1999 3500 It's completely stock aside from the vp44 and my newly installed raptor FRRP 100gph lift pump. The vp44 isn't a hotrod as far as I know I believe it's a stock replacement, previous owner had it done. The truck runs fine at any speed, matter of fact it has more pulling power and better throttle response so I'm reluctant to say my VP is bad? My issue is it is very hard to start after installing my raptor. The morning previous to install, it started perfectly fine, fired extremely fast, got home from work did the install and it's been hard to start ever since. I have to give it some throttle otherwise it won't fire. I ordered a new vp44 overflow valve, past that any ideas?
