Solid State Relay for ECM-Controlled Lift Pumps?
- Replies 10
- Views 2.8k
dripley 2 posts
IBMobile 2 posts
Tractorman 2 posts
LorenS 2 posts
Popular Days
My 02 is the same as @Tractorman. 1/4 second or 2 seconds, I just cant what possible difference it could make. If your truck is a late year 01 it is probably more like an 02 tan an 01. I think Dodge
Most of us that run a mechanical fuel pump either have the electric fuel pump disconnected, like I do, or don't have one installed at all so we never see nor need that ¼-2 seconds of initial fuel pres
Key on pressure is nothing... That little burp of pump is the ECM booting up and the lift pump runs for a brief second pulse then off again. Lift pump doesn't get any signal till the crank sense. Now
It's been my observation that since I put my lift pump on an ECM-triggered relay that the pump (none of three tried) doesn't do its normal startup routine. I hypothesize it's because the pulse-width-modulation signal from the ECM isn't reliably making my normal relay close. In a semi-unrelated internet search this popped up. It's a solid-state relay that fits the normal mechanical relay base.
Hella part number: H41773001 http://hellahd.com/index.php/default/electrics/relays/mini-iso-relays/12v-spst/h41773001-931773987/
https://www.lingenfelter.com/PDFdownloads/HELLA41773001.pdf
Thoughts? I expect most will be 'that's a solution to a problem that doesn't exist'
EDIT: I see that the duty cycle is only 90%,
but I don't know if that's at the max ambient of +125 degrees Celsius. Surely a lower ambient could boost that to 100% duty cycle.This is incorrect, I believe. The 'rated amperage' at 85C (185 degrees F) is 20 Amps. I guess the 'maximum ambient' of 125C is for when it's just sitting around on a shelf.Further edit, I read the 'base' is different than a "normal" relay, so some wiring switcharoo in the relay base would be needed. Easy to do, just something to remember.
After all these edits, this may be a terrible idea!
I've used these in my homebrew setup for a while with great results, but that's obviously not in an underhood environment:
https://www.amazon.com/TWTADE-SSR-40-3-32V-5-60V-Solid/dp/B079BGGVYX/ref=pd_sbs_5?pd_rd_w=nfADM&pf_rd_p=ed1e2146-ecfe-435e-b3b5-d79fa072fd58&pf_rd_r=5QE4JEKCV24F2YA3MVS8&pd_rd_r=d231ae23-7cb1-4c3f-853d-c0c6ac98488c&pd_rd_wg=NqsDN&pd_rd_i=B079BGGVYX&psc=1
Edited by LorenS
