Seatbelt indicator light issue
- Replies 9
- Views 3.1k
leety 3 posts
dripley 2 posts
SilverMoose 2 posts
Dieselfuture 1 post
Popular Days
I would just jump the wires down under the seat. The two wire jump together turns off the light. The only solution is to get a new driver side seat belt latch to replace the wore out one.Either way it
Use an ohm meter to test the buckle
Mine did the same for a couple years until it finally just stayed on all the time. I bought some seats about 4 years ago and installed them and light has stayed off ever since. Of course my seats, dri
Hi all,
So my the buckle on my driver's side seatbelt was flickering the light. If I pushed it in it would go off, for awhile, then it the light would eventually come back on.
It got tot he point where the light would only go off if I pushed the seatbelt into the buckle, full-time.
I purchased a new Mopar part from ebay, they are not cheap. Replaced it and it worked as expected. Them my truck sat for about 6 weeks. On the first trip out the overpriced new buckle started doing the same thing the old one was doing.
The good news the part has a 2 year warrantee, and they sent me a replacement.
The bad news, the replacement is doing exactly the same thing. The seatbelt indicator light is on, The indicator light only goes off when I push and hold seatbelt into the buckle.
It is possible that I just got 2 bad parts?
Or is there's something else I should be looking at?
Any thoughts or suggestions on possible other causes would be most appreciated.
Edited by leety
