Bucking on warm starts
- Replies 16
- Views 3.2k
Mopar1973Man 7 posts
Dirty 7 posts
dripley 1 post
Dieselfuture 1 post
WT mod and check ac noise is the first thing to get done. Then check all other cables/grounds, then we go from there. How low? Just what you said foil and bd isolation this means you hav
These are very good signs of excess AC voltage. I have to agree with what @Dieselfuture says. Dont assume anything is good with out checking it. The trucks thrive on good clean DC voltage.
The sad part is someone as a member here or members have had this kind of problem. Hence we post about it and share what is going on and create articles so we don't forget how to fix said issues. This
First time posting but love this site.
I have a 99 Dodge Cummins. Roughly 160,000. This issue started roughly 6 months ago. The truck runs great until a warm restart. Then in bucks and surges a bit when I hit the throttle and eventually goes into limp mode. It has never done it on a cold start. I can put money down I can start it in the morning and it will be fine. I’ll drive to town with no issues. If I shut it off go into a store and come out it bucks and surges then goes to limp mode. It results in a p0606 code.
So when it first did it I changed the APPs out to a Timbo apps. I have also changed the MAP and IAT. I sent the ECM off to get repaired. Oddly enough when I got it back it ran great. Way more power then it had. However I then developed the torque converter lock up issues. I did all the usual stuff. Moved the ground cable that runs by the alternator, foiled it, and added the BD noise suppressor. Cured the torque converter lock up issue. Thought I had her licked. Drove it today about 10 miles...went into a store....when I came out and started it the problem came back. Not sure what else I can do. Alternator noise seems to be low. I’ve gone through all the grounds.
Any thoughts?
