- Replies 10
 - Views 2.2k
								Mopar1973Man 4 posts
								Doubletrouble 3 posts
								dripley 2 posts
								AH64ID 1 post
After a 3 year long of not running... Stuffed in a new Valair quiet towing dual disc clutch and a set of +50HP injectors. It runs! It's been so long since I last drove it that it was like a all new experience. No real smoke at all. Remember there is no tuner just the +50HP injectors and stock ECM. I rolled out 18.2 MPG on the way home at least on the overhead display. I need to set up my app for this truck and start monitoring the actual MPG which might be a bit better being this does have oversized tires (33 inch). Ratio is wrong and runs on the hot side climbing grades.
Oh yeah I found out that 2006 and up are chipped keys. Man talk about expensive to have cut. I had a original key and fob it was 175 dollars to cut and program the new key. Even got a extra key non-chip for a door fall back. If you attempt to set without a fob key it will start and run but a red light will come on and then it will die because of lack of chip being present during the start up. All the alarm functions do work too.
Way back home set the cruise at 65 MPH it was nice to have the auto exhaust brake function to maintain road speed correct. As I traveled down the grade the exhaust brake would turn on and off as needed to hold the road speed. Really nice feature. Cab is really comfortable to drive in for long hauls, seat wise. The driver seat has that hole next to my left hip also fixable with a new foam pad and bit of sewing. We stuff the back seat with groceries and other stuff.
I'm still finding small little things that need done to make it all right. Need a new stereo head. Fix the mirror so the door controls work. Fix the fog lights (missing the turn on switch). Other than that I'm quite impressed with this truck. Oh yeah part of the EGT issue is the wastegate solenoid too. (broke lead).
Next step is to sell the 1996 Dodge 1500... Time to retire "Little Red".
