Head studs
  • Replies 41
  • Views 13.4k
  • Throttle Brake Parking Brake BOOM!  3 pedals. One hand holding my coffee, the other holding the wheel and operating the turn signal. :D
  • Blueox01
    Blueox01
    New toys to play with
  • For the longest time I've wanted a 3/4 ton, square body Suburban with an ISB 4 cylinder and one of Fuller's automated manuals. FO5506B may be one of the model numbers that's close. I like to sip coffe
On 5/5/2021 at 3:42 PM, Blueox01 said:
Anybody know anything about Xotic performance head studs
Not personally. I'm on a VP44 page on Facebook, and lots of guys run them. If the numbskulls on that page can't destroy anything using those studs, they must be pretty decent. When the time comes I may install a set.
Same here. Never heard of them. I put my money on the 425 ARP studs. Even though I blew my head gasket a second time.
Well, I bought them, 265.00 shipped, tested by an independent lab Atrona test labs at 240,000 psi, good enough for me, I'll know in a year how they hold up.
Danm, you should have told me, they had a BOGO today!
"Even though I blew my head gasket a second time." Not the best statement when promoting a product:doh: Sorry Mike I couldn't resist.
Edited by Blueox01
I don't think the studs was my problem.
Between high timing on the Quad and possibly high exhaust back pressure done the damage for me. I'm already got the head shipped off and need to order a new head gasket from DAP. When I fire back up I will disconnect the wire tap till I can source out a bigger turbo and a new exhaust brake as well. Being my current exhaust brake limits my turbo choices. Do a in pipe PacBrake will open up options for a bigger exhaust housing and bigger turbine and compressor wheels.
Trust me, I have learned from mistakes.
Drat!!
Just my :2cents:, but the only gasket I ever had fail was after market in this short of miles and I broke the rules and used Cummins bolts 4 times, I know Cummins( I get my parts from Freightliner) is more expensive than any after market, but manufacture's are the first to improve any product deficiency.  Never had a gasket leak like this Mahle.
On a different note got my FSO8406A reman back. I bought this with who knows how millions of miles, out lasted any NV5600 I owned. Inland Truck replaced input shaft,1st/2nd/3rd gears all sync's,all bearings,top cover was wallowed out shift rails are, shift tower etc. etc 2 year unlimited miles (I will make sure it's tested) in 2 years.1819903144_20210511_1404371.jpg.018a8a21b61398ec017c7175a1636dd6.jpg
On a different note got my FSO8406A reman back. I bought this with who knows how millions of miles, out lasted any NV5600 I owned. Inland Truck replaced input shaft,1st/2nd/3rd gears all sync's,all bearings,top cover was wallowed out shift rails are, shift tower etc. etc 2 year unlimited miles (I will make sure it's tested) in 2 years. Dripley better not make fun about my straps!!!!1819903144_20210511_1404371.jpg.018a8a21b61398ec017c7175a1636dd6.jpg
For the longest time I've wanted a 3/4 ton, square body Suburban with an ISB 4 cylinder and one of Fuller's automated manuals. FO5506B may be one of the model numbers that's close. I like to sip coffee and be a "steering wheel holder", not shift gears through every dinky town, or rush hour in big cities :)
I think someone elese made fun of the straps. If works use it. I am curious of what that rebuild cost. It sounds expensive. Some things are worth the money though. My 5600 is in need of some service work. I got a spare I am thinking about sending to Super Stick in Texas. He has a good rep on the 5600.
$3136 and change
Real trucks have 3 pedals.
  • Popular Post
Throttle
Brake
Parking Brake
BOOM!  3 pedals.
 "already got the head shipped off".... Just curious, who's doing the work on your cylinder head?. I noticed there are several machine shops locally (Boise area) but don't know about their reputation.
I chose Northwest Motor Machine
4218 Dearborn St, Caldwell, ID 83605
(208) 453-1292
https://northwestmotormachine.com/
These guys work mostly with Cummins engines. Matter of fact they are looking for core engines they are short on Common Rail cores right now.
(208) 453-1292
That's exactly who I was looking at should I ever need any machining work done. Let us know how they did.
First trip to there shop was back at 350k miles roughly. I blew the back of the head gasket for the coolant jacket. It cost me $2,100 for 18 of the 24 valve guide, valve seat ground to spec again. This trip 431k miles, I blew the head gasket on the front driver corner leaking oil. I was only $425 to straight out the head that 0.006 of warp. New set of valve seals. Ron and Justin are wonderful people to deal with and prompt on getting the job done. Both trips it was a mere 3 days as quoted. I would use Northwest Machine for my future rebuild of the engine as well.
This is going to be a stupid question, the head stud directions says to screw in the studs without applying torque, but surely the want them tight in the block, not just finger tight, Right. I was able to thread the studs in by hand, but still loose in threads, these should be snug I.E. bottomed out in the block, Correct?
Edited by Blueox01
I left about 1/2 turn out but after torquing to 125 foot pounds I'm pretty sure they bottomed out. I lubed both ends...
