- Replies 54
- Views 8k
Nathan S 17 posts
Mopar1973Man 9 posts
Silverwolf2691 9 posts
Dieselfuture 4 posts
Or a bigger hose clamp. @JAG1 can help.
I think you are correct. I think it will perform much better at the higher rpm's. - John
None here... I've only used a HX35W and HX35/40 Hybrid... Ummm... I'm not very smart about turbos... I know its got a spinny thingy that spins really fast and makes all kinds of weird h
Last fall I “upgraded” the stock hx35 on my truck to a Calibrated Power Stealth 64 Hx35. This turbo is the same basic frame as a stock hx35 so I can still use my Jacobs exhaust brake. Calibrated power makes their own 11 blade billet compressor, compressor cover. They also make their own turbine wheel which is larger to match the larger compressor wheel, and use a 9cm turbine housing. I think this tight turbine housing is what is causing my issues. I have been battling egt problems with the truck since I put the turbo on. I’ve upgraded injectors after finding posts discussing the effects of too small of an injector with out enough fuel causing high egts. I have updated the old Edge JWA to a Quadzilla to be able to custom tune and have spent the last 6 months trying to get the egt back to where it was with the stock turbo and 75 horsepower injectors.
Accelerating on the highway, at less than half throttle I can see 1350 on the egt pretty easily, with the truck empty. I sometimes carry my rzr side by side on the back of the truck on the flatbed, and with it on the truck, pulling a relatively large grade in northwest Colorado I struggled to keep the temps below 1300. With the old setup I would barely break 1200 with my 10,000 pound fifth wheel on the same grade. You could say I’m less that impressed with the turbo.
I have been all over the truck searching for boost leaks, change every seal, gasket and o ring that could be causing a boost leak. I really feel that the increased compressor flow with the tighter exhaust housing is what is causing my problems. Does anyone know if I could buy a stock housing and have a company bore the housing out to accept the larger turbine? I’ve talked with Calibrated power about this and they told me they do not offer any other housing for this application.
