APPS TPS failure expectation
- Replies 40
- Views 7.6k
beautifulisblue 18 posts
Mopar1973Man 13 posts
JAG1 5 posts
IBMobile 2 posts
In conjunction with the W-T ground wire mod you might want to do this also. PCM Ground Splice Repair - Electrical - Mopar1973Man's Dodge Cummins Forum https://mopar1973man.com/cummins
You gotta love the Dodge OE wire splices. I don't know where they came up with that idea but it has to be the absolute WORST way to splice wires together. The W-T ground wire mod exposed this flaw and
Timbos APPS would of been a much better solution. If its repaired correctly the error code should be erased and not returned. The only thing that will trip the APPS error codes is voltag
Hey folks I got a low voltage code and replaced the TPS APPS with spring etc from Napa. I did not adjust it, tonight I got some cutting out on the highway.
I've saw the description for diagnostic on alternator, ECM, etc.
My question is should I worry about needing to drive 200 miles tomorrow hauling a light trailer? I have my four year old with me and want to make sure it will likely be annoying not catastrophic.
We stopped and I pulled the battery cables and turned the key, reset apps and got no more cutting out the last hour of our drive tonight.
Thanks
Edited by beautifulisblue
