Well pump running 24/7........
- Replies 7
- Views 2k
Mopar1973Man 2 posts
JAG1 2 posts
Dieselfuture 2 posts
Doubletrouble 1 post
Popular Days
AAAmazing, Thank you Dieselfuture. We hit water when drilling in 1995 at 51 feet it yielded 50 gallons per minute at the time. Then driller said I'm going another 10 feet for summer drop off. I said g
In reality if the well doesn't run out of water and pump sucks air and overheats along with doing damage to impellers from cavitation then it should be fine. It gets cooled by the water. If you have p
Generally you want to do it 2 times, it's called drawdowns. Once before the well kicks on so the water had time to fill the void space called cone of depression, then second time right before the well
I have trees showing stress from lack of rain and excessive heat, so for past week I have been running my well pump 24/7 moving the irrigation every 24 hrs. The trees after a day or so are looking better. It's a good well never runs out but, I'm concerned for the well pump down in the well at 71 feet. My well guy sold me a ceramic pump, is now 26 yrs old, is showing no signs of weakness. I can run two hoses full without weakening pressure and supply the house just fine'
My question is Should I give the pump a rest? Been going for a week now.
T.I.A.
